TwinTurbo.NET: Nissan 300ZX forum - I have the exact same clutch and have used it with
Audioquest
on April 11, 2008 at 9:50 AM
Question about the RPS Sport Street clutch.
posted by frank1991(running again)
on April 11, 2008 at 09:46 AM
stock and RPS lightweight flywheels.
When you say you have to push the pedal a few times to "engage" I assume you really mean disengage to release the clutch to shift gears etc?
09:46:25 04/11/08
I have the exact same clutch and have used it with -
Audioquest
09:50:23 04/11/08
Re: I have the exact same clutch and have used it with
09:55:20 04/11/08
Re:I have the RPS Lightweight segmented flywheel (n/m)
09:56:56 04/11/08
Did you b;eed the point on the pass fender well
Audioquest
10:00:51 04/11/08
Re: Did you b;eed the point on the pass fender well
10:02:55 04/11/08
With an upgraded clutch it helps to do a couple things.
Audioquest
10:06:54 04/11/08
Re: With an upgraded clutch it helps to do a couple things.
10:22:10 04/11/08
I forgot to mention, if you go to adjust the clutch
Audioquest
10:50:35 04/11/08
Sounds like you're building up pressure
spicyZ
14:06:48 04/11/08
Re: Sounds like you're building up pressure
15:08:26 04/11/08
In that case, it sounds as though it's misadjusted :-/
spicyZ
15:37:59 04/11/08
YEs, as it warms up so does the fluid and any air in the
Audioquest
16:13:09 04/11/08
Re: YEs, as it warms up so does the fluid and any air in the
19:04:12 04/11/08
Quite often, but if it isn't to that point, maybe not.
Audioquest
20:23:02 04/11/08
2nd - slow fluid leak somewhere... (n/m)
jzack
20:53:36 04/11/08
You can't build clutch pressure like it's brakes (n/m)
en5
22:50:34 04/11/08
You can't? Coulda fooled me. (n/m)
spicyZ
15:30:35 04/12/08
It doesn't build pressure up, once you press the pedal
en5
18:24:29 04/12/08
TT owner --->
spicyZ
09:51:08 04/13/08
converted NA no clutch booster (n/m)
10:04:13 04/13/08
